Is it safe to cut the JST connector off a store battery pack without damaging it or causing it to short?
Welcome to saber building. You've taken your first step into a larger world.
"Don't get the idea that your [lightsaber] is a quick little project to be slapped together." - Luke Skywalker
Yes, just make sure when you cut, and strip that your pliers/strippers don't accidentally touch the other (especially an exposed) wire at the same time. I sometimes use a piece of pre-shrunk wrap as a wire-nut to cover one wire while I work on the other.
Ok that's what I thought but I wanted to be sure. Better safe than sorry! Thanks.
