So I am finally am upgrading my GOW replica lancer with a blaster core. I figured since a lot of people here use Crystal Focus boards, and they are the same concept. I was hoping somebody would be able to help me.
Ok lets see if I can explain this without my head exploding. LOL
1.The first picture shows two switches inside the clip receiver those are the two switches that currently powering the two sound cards I currently have in the lancer. I plan on using only one of those for the clip sound effects.
2. Trigger (not pictured) Kinda self speaks for it's self LOL
3.Toggle switch (currently used to go from auto to silenced mode) Will be used to go from auto to single shot.
4. Momentary button. This will be my Aux button.
To wire this thing up (if I am reading the manual correctly. For each "switch" the positive will be soldered to the respective spot on the board. Then all of the negatives will be brought together and soldered to the ground terminal.
I don't plan on adding a recharging port. This will simply use rechargeable batteries (will have access to the compartment) Will be powered with a micro on and off switch. The Blue Led's will be set up between the switch and the board so when I turn it on, the lights come on and the Blaster Core receives power.
I think for wiring I am good to go. For the sound fonts do I simply have to drag and drop them to the SD card.
I have been thinking about this all day. I hope I am right.
comments and constructive crit are always welcome.
