So i picked up an Ultra saber hilt from there 55.00 grab bag so i can have an offhand wepon but the questions is can i use a Corbin style blade from TCSS since i like the look of the blade better thank you for any help?
Check the width of your current blade. It should be either 1", 7/8", or 3/4" in diameter. You can pick up a blade from TCSS in that size, and it should fit.
You may need to sand the blade a bit if the fit is too tight, or wrap it with a little clear tape if the fit is too loose.
Yes. I have a blades from US and TCSS and both are interchangeable. At least with the hilts I've built and the old US Prophecy and Initiate hilts.
"Because your own strength is unequal to the task, do not assume that it is beyond the powers of man; but if anything is within the powers and province of man, believe that it is within your own compass also."
-Marcus Aurelius, one of the Five Good Emperors of Rome
