Results 1 to 4 of 4
Thread: Question regarding the Vader conversion tutorial
    Question Question regarding the Vader conversion tutorial
    Hi.
    I noted that on the tutorial, nothing was said about the use of a resistor. Is one not needed? In this pic showing the wiring from the tutorial, and correct me if I am mistaken, but there is no resistor shown:
    http://i112.photobucket.com/albums/n...l/IMG_3681.jpg
    Or, is the thing the gray wire is attached to the resistor? Please forgive my ignorance, as I am still learning. All this is very new to me.
    Thanks.
    Depends on your LED. I've used Seoul P4's with with no resistors for my reds when converting and never had any issues.
    Youngling Jordandau's Avatar
    Dec 2009
    North Hollywood, CA
    220
    With reds I'd be careful. I'd measure the output first and see if one's needed or not.
    I did mine with no resistor. Used Lux 3w deep red. It works great. That thing in the picture connected to the gray wire is the clash sensor. It comes out of the blade. Tricky little suckers.
