Hi all! I wanted to go ahead and use this as my first "official" post for my first saber build! I have been in the forums for a good long while at this point researching, learning and doing ALOT of reading, but I am in need of a bit of assistance.
A couple years back I built my saber. I was just using it as a prop on my belt as a secondary saber due to cost restraints, and I have been slowly buying up the electronics I need. I now feel I have everything I need (shy of my PCB and some resistors), but I can NOT for the life of me find a wiring diagram that matches my setup.
Here is the general "guts" of my saber: http://i817.photobucket.com/albums/z...berinnards.jpg
Here I have an Ultrasound V2.5 board, a speaker from TCS with a basic battery pack, a Lux 3 Blue LED, a Blue Latching Anti-Vandal Switch, and a recharge port. I have a basic wiring diagram set up, but perusing the internet hasn't yielded much more than broken Photobucket links and URLs. So in short, my questions are:
-Can I use the battery pack I have for my Li-Ions (2 TrustFire 3.7V AA sized cells) or do I need to incorporate a PCB? Unsure if I need too for 7.2V of power.
-Does anyone know of good wiring diagram showing solder points for the Ultrasound V2.5 board, or have previous experience doing so?
-Does the Ultrasound V2.5 board regulate current? Basically I just need to know if I'm going to have to use resistors leading off of the board to the Anti-Vandal and the Lux 3.
Being my first build, any critiques or input would be greatly appreciated. I am so excited to be at this stage in the building process, but I need to make sure I do it properly, as my electronics knowledge is relatively small, but growing.
Thank you everyone for the great information you have provided so far! I hope I can pick your brains just a liiiiittle bit more
