I am trying to use a short anti vandal and am kind of stuck. The long wired fine I just don't get the short.
Thanks
Thanks
The third picture in the store shows it. + & - led are marked, other two are switch leads, doesn't matter which. The long one is the harder one to get.
I got it to turn off and on. Can't get the switch to light though
Can you give us a photo or two of your wiring? Perhaps then we can see what is up.
pics added
That is a latching switch. The Jst's will hook up to the other two for your light. My mistake earlier, I thought you were using the momentary switch. Depending on how your hooking it up you might need a resistor.
So battery jst to small pins, then the tabs out to the led? Resistor before the switch on the negative.
Now that I see the MWS buck puck I see some other issues. This happens all to often, You should look at the back of the board, and the description of what they mean here . What you should have asked for was was a wiring diagram for the mws buck, it is not voltage - & + in as you have it wired. You also have the switch in the wrong place. The two pins for your jst to your switch led are marked A-,A+ on the rear of the card, along with where your switch, battery, etc go. The resistor goes to the two marked ARES. it completes the circuit , so no resistor, no light.
Check out this post Tim explains it better than I do.
