Can the RGB LED's be installed into a customized ForceFX Saber?
These are cool..but remember they are dimmer than a standard 3w of the same color and you also need a special circuit/switch setup if you want to be able to change colors.
how much dimmer? can TCSS do the special wiring?
DB
I'll Be Listing a Color Changing vader on ebay just after January 1. I requires the additional switches but is quite simple to wire. for all those that have one coming I'll tell you that you wire it up with the positive as the common or C on the LED. The RGB connect to the negative and with all the grounds tied together from the plug the LED achieves the brightness of the others. I'll Post a wiring diagram soon. If anybody needs help in wiring before then just IM me or send an Email
the website mentioned earlier inthis thread has 3 models of "full color" LEDs, which one is the brightest? the red looks the dimmest in almost all colors of EL or LED, but it seems to vary from model to model of these multis.
suggestions?
DB
the blue green photo looks like a lime color. looks good.
