hi guys im just wondering if anyone has found that the mid grade white poly cs are whiter or diffuse better then the heavy grade white poly c?
wow 71 views and no one can answer this question haha
I've used the thin walled version. It works pretty well. I've never used the thick walled variety, so I can't compare the two.
I've used both. The mid grade seems a bit brighter but is more whipy when swung and hit. The heavy ones, which I have in both stunt sabers, don't transfer light quite as well to the tip and, to me, seem just a tad darker. They don't flex as much as the mids but are heavy, you will feel that extra weigth between the two and more so after 3 hours of work.
Knowledge must be balanced by Practice.
Practice must be balanced by Experience.
Through Knowledge, Practice, and Experience
we gain Wisdom.
-Boj-Vaati Mau
Jedi Sentinel, Jar'Kai practitioner,
and Instctor at Strafe Plains Temple
Saber Guild: Strafe Plains Temple
The Rebel Legion
Of course, the trick to getting a nice even blade is a few wraps of clear polypropylene (clear gift wrap) inside the blade.
Either will diffuse quite well. The amount of Poly-P used will vary. I personally use 4' in the thin walled and ~2 1/2' in the thick. Both are bright and even.
