Yeah, what Strydur said. Not even a 1 watt would look like that. Post a pic of the LED with the wires soldered on, I suspect you have something criss crossed.
FYI, the clash sensor wire and purple wire should be soldered to the positive post and all the other wires should be soldered to the negative post.
Do i need the shock sensor to make it brighter because when i wired it up like you said it was the same but i didnt have the clash sensor hooked up.
The impression of the Sith will never return, you have lost - mace windu
But is the clash sensor neccesary?
nope
So how come mine isnt as bright then? I have it wired like in the pic you posted Tim. Do I need a collimator lens? Is everyone aware that I am using a white led with the color discs and if this is how it is supposed to look can i just exchange the white led for a green led?
You dont have any lens on it? that could do it also
Are you sure you have it wired like the pic? It looks like in the pic you posted that you only have 1 negative wire coming out of the sound module.
Well once I saw the pic you posted I rewired it. Is the lens neccesary?
i just wanted to say, i am pretty sure that mace windu says opression, not impression. [] just thought i would let you know, i could be wrong
