Originally Posted by
lonewolf
If your batteries are still raw batteries, there are several chargers that will do multiple cells at once, like the Xtar WP6 II. This depends on you using a battery holder in your sabers, though. I'm not sure of any solution like that using multiple JST connectors, but I'm sure you could cobble something together to work.
If you go with recharge ports, you're pretty much stuck with multiple chargers, as far as I can tell. I guess you could create some wires that would have a charge plug on one end and a dummy "cell" on the other to plug into the charger. Obviously the dummy cell would have to be non-conductive or you'd short out the charger. The problem then is that all the sabers would have to be brought to the charger, which could be a mess. And you still wouldn't be able to have spare batteries.
What is the problem you're having with the battery cases? I'd probably wire the battery holder itself with a JST connector so that you could unplug it if needed, but could still remove the individual batteries from the holder to use on a bulk charger.
