Results 21 to 30 of 35
Thread: Purple!
  1. #21
    If you put the resistor before the splice, then it will be applying the resistance to both your red and blue leds. You only want to reduce the power to your red led.
  2. #22
    Ahh, makes sense. Thanks!
  3. #23
    Considering I have no idea how to use a potentiometer -- or where to acquire the right kind, if there's more than one -- I think I'm just going to grab a handful of resistors as suggested in this thread and just play around until I get my ideal mix. That being said, what range would be recommended? Is there anything that would be either too weak or too strong?
  4. #24
    Quote Originally Posted by Maleficia View Post
    Something like a 10 Ohm, 1W should get you in the neighborhood. Get the next size up and down and you should be in good shape.
  5. #25
    Potentiometer is just a fancy word for a variable resistor. You've seen them before, but you may not have realized it.
    Volume control knobs? Yep, they're potentiometers. They usually have a dial or a screw on them that you turn to adjust the resistance.
  6. #26
    Well, if you wanted to use a POT to play around with color mixing, I'd go for one of these, a 10ohm wirewound POT. Just use the center terminal and one of the side ones. But realistically, you're likely to find what you're looking for with 0.5 to 3 ohm range, 2Watt resistors (just to be safe). Best fit for nominal operation of that red LED is going to be 1.8ohm, 2Watt. If I were going to be doing the color mixing (and I will probably make a purple one later this year), I'd leave the blue at nominal voltage with the "drive" setting, and then play around with the red LED resistor -- since I like 'em a little more on the blue side, I might bump it up to 2.2 or 2.7ohms and see how it looks. (and if you want more red, just reduce the red LED resistance and reduce the "drive" setting).
  7. #27
    Huh... I was not aware of that. Ya learn something new every day!
  8. #28
    Quote Originally Posted by Xevious View Post
    Excellent. Thanks for the tip! I'll grab a few of those resistors and swap 'em out until I get the color I want.
  9. #29
    Sure. As long as you can fit two resistors in the hilt OK, then it might be easiest to just leave the drive setting to max and just swap-out various resistors on your benchtop 'till you get what you want, knowing it'll look exactly the same when you assemble it. Just don't let the red LED get too much current or it will fry.
  10. #30
    Does anyone know what the amp output of the Mace Windu Master Replica card is? I measured the voltage and its around the 3.6v range with a fresh set of batteries, but amperage would vary depending on what the draw is correct? I just don't know what the max draw is that we have to work with. Any info would be appreciated.
