multiple LED's
would it be possible to wire additional LED's for the outside of the hilt to the same activation switch/battery source? i'm looking to put decorative LED's on the outside of the hilt on my next saber and wanted to know if this was possible. if it is, would you wire them parallel (if that's right) or not? meaning, something close to this poor diagram:
switch---\led---\led----\led (for blade)
battery--/------/-------/
sorry i'm way off base with this, but didn't know how else to word it
vade - yes i am talking about using regular radioshack LED's for the decorative part. i'd seen them used on other sabers, and how they were wired for that particular saber, but i had never seen them in conjunction with a blade.
xwing - any idea what size resistor i'd need for each LED?
GeluKhanGharr,
do you think you could show which lead off the battery and the switch would go to each circuit? i know the battery pack will have pos/neg leads, but which one would go to the switch? i may be mistaken, but i thought that the standard on/off switch has the same pos/neg leads, and which would go to the luxeon led, and which to the decorative LED's?
thanks!
