Results 1 to 2 of 2
Thread: "new style" led module question.
    Default "new style" led module question.
    I haven't built a saber in a few years so I decided it was time to come back and drop some cash. I saw the blade holders are now a different style when it comes to the led module, and I was just curious about how the new module was held into the blade holder. In my MHS saber, the led and lens are held in by screwing the blade holder into the choke. Effectively pressure fitting the led and lens.
    I only ask this because I plan on using an UltraSaber hilt but with a TCSS blade holder/ seoul p4 led and MHS heatsink module, and I wanted to know if there will be any issues with the module staying put.
    Thank you all ahead of time for any help you may be able to offer. And if there is any other info needed, please ask.
    In the new style LED holder the top piece screws down onto the threaded heat sink base effectively holding the lens on top of the LED. The whole unit is then held in place like you said above between the blade holder and the part the blade holder screws into.
