5watt w/ sound and cooling fan
Hi all. My first post here. Let me begin by saying that over the last few days, I think I've reda every post on this forum, and wow, that's a lot of good info. Thanks for that.
As the title of this thread may lead one to believe, I'm building a 5w LUX with sound and a cooling fan, and I need a little help. I've sourced out a fan that will fit in the MHS, which runs on ~5v and draws .16a - and at it's less than an inch across, and 3/8th of an inch deep! I have a little background with electrical design, and with that, I've put together a solid idea (IMHO)
Here's my proposed wiring:
I'm using the 8xAA's so that I have a decent runtime. If I had to, I could go down to 4xAA or 6xAA and run 6v or 9v across the project without a problem (the beautiful part about the Puck drivers...)
I need some help in figuring out what size resistor to put in there - I've searched these forums and not found a amp rating for any of these soundboards. Anyone have an idea? If I can get an idea of the resistor size then I can put this thing together...
Thanks!!!
(BTY, Stryder, I'm not going to post where to get the fans, but it's a bulk order kind of place. If you want it to add to your lineup -hint hint-, I'll share with you if you want it. Send me a PM)
Actually, thumbing throught this catalog, I see another fan that runs 12v directly, has a much higher CFM, and would still fit in an MHS, so here's an alternative schematic...
Might be a little more efficient by moving the fan away from the resisted circuit. Also avoids sending that extra .16a to the SB, which is these things are as touchy as everyone makes them out to be, would be a good thing.
Any thoughts?
I'm also thinking that a fan would add a nice little tactile feel - a slight vibration in the grip.
As to the durability of the fan, there are no connected moving parts (how it's so small) - meaning no ball bearings. It uses a balanced magnetic suspension system. Relatively new thing (came to market like 2 years ago) and is a very clever design advancement.
Third, I was going to use a MHS holder, extension and sink tube adapter, and put the sink tube to fit the batteries. No idea for a pommel, yet.
Thanks for the lead Maul. I'm going to go do some math now...
Maul better know as private pyle, again with his foot in his mouth
