Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: Novasound Neutrino Soundboard Components Help?
    You will need a momentary switch. Latching switch will work, but it makes navigating the menus extremely difficult & totally not worth the frusrtration
    As for the intensity setting. You'll know when you get the setting right b/c if it's not set right this board will cause the sound to be grainy if you have the intensity set wrong.
    I have a wiring diagram to wire this up with a recharge port. I will upload it once I get home for you.
    no resistors are needed in thia set up. Neutrion board with a recharge port & li-ion rechargeable batteries
    Jul 2012
    584
    Thanks for posting that recharge port diagram Kaide - i plan on using it soon myself!
