i have an 05 MR anakin ROTS
i received and installed my conversion kit hardware from TCSS which went together PERFECTLY.
i did NOT use the standard single LED method that's generally accepted in converting though.
that's my question. i'm not too experienced in electronics so i was wondering how i could go about making a simple quick connect for the existing FX saber LED tube setup?
i know following this link that you simply cut the wires and then solder all but one (not including the blue wire) to the negative and the pos to all the rest for luxeon LED or the like
http://forums.thecustomsabershop.com...kits-available
but what if i wanted to use the same LED string wiring and perhaps a 1/4" cable plug from an instrument cable or maybe a USB plug like this link?
http://www.fx-sabers.com/forum/index.php?topic=13553.0
would i simply do the same thing? just wire them all into two wires for the connection point?
again i basically just want the same type of functionality that my 2010 ANH FX saber has where i can just plug the FX LED saber tube into it for it to work rather than do the single LED method.
thx
