Results 1 to 10 of 17
Thread: Thoughts on blade sizes
    Default Thoughts on blade sizes
    Howdy all,
    Lately I've been playing around with the 7/8 blades from TCSS. Any one else?
    At first I was not really convinced. I did a lot with 3/4 blades and was mostly disappointed every time. So I went with 1" transwhite, which I really like and am still a big fan of. So I purchased my first stock of 7/8 not long ago and built a couple of them in different lengths.
    First I did my standard 34"(32 installed) and I was very happy with the effect. So I went up to 36" (34" installed) and found (MO) that the 7/8 blades with diffuser in them really push the lite the full length of the blade.
    Here's some of what I was talking about. Both blades have exactly the same amount of diffuser in them. I measured each piece of diffuser the same for both blades.
    First up the 7/8 transwhite blade, cut to 34" (32 installed) with a Green Rebel LED.
    Next the 1" transwhite blade, cut to 34" (32 installed) using the same hilt and LED.
    To me at first they appeared the same. But on further inspection of the 1" blade I noticed a bit of a dimming effect near the middle. Where on the 7/8 I found that it was solid all the way across. Of course this could be just my eyes. Also I'm still doing a bit more testing
    But I thought it would be interesting to see if anyone had any thoughts on this.
    Personally, I'm not a fan of transwhite.
    I agree with IndustrialAction, not a fan of transwhite.
    im a fan of transwhite, and i've been curious about the 7/8" blades. so, THANKS!
    i have a question though. how do you fit the 7/8" into a 1" BH? i've seen 3/4" blade adapters in the store, but not 7/8"? did i miss something? and how did you affix the adapter? "permanently" to the blade? or longer blade retention screw with a hole drilled through the adapter?
    just curious as i'm not able to see any vids or pics (darned gov't network).
    thanks again!
    NOMING YOUR POWER CABLES SINCE 2007
    MHS #1 "Coppertop" CFX Neopixel
    MR 616 "Joe Jedi"
    LDM converted Korbanth LS6 (Hero with PC 1.6 and FOC)
    Vintage graflex ANH - probably staying static
    Disney Savi Saber Peace and Justice (experience was worth it)
    I have yet to really try the transwhite blades as of yet, so I can't comment on them. But I am seriously considering making 7/8 inch blades the standard size for my sabers. I can always add a piece of 1 inch tubing to make an adapter for hilts that require it. The more I look at the 7/8 they seem to really fit the bill. 3/4 are too narrow and not as durable (at least in thin wall) and the more I look at 1 inch blades they seem to be too bulky. Not to mention that the 1 inch size bulks out the ring attachment on the bunny ears on a Graflex, making it look funny. A 7/8 blade should eliminate that. Plus, because my thin necked sabers will have a 7/8 blade, by making it my standard size for all of my sabers it will make my collection all uniform (as well as equal when dueling with them.)
    Follow Your Bliss
    For the record, I am a big fan of the transwhite blade stock, and actually have the pieces here to make a 7/8" blade, but have yet to get around to it.
    Hmm, I see there are not too many fans of the transwhite. At least that responded to the post But I will say that in a few cases (MO) the clear blades do provide a good effect for some colors that I have seen. I don't use the clear too often, but when I do I am still happy with how they turn out.
    As for the 7/8 (to answer Mynock's Q, if he has not seen it in the post yet) for the "adapter" a piece of 1" thin walled blade stock cut to 2" or so makes for a good adapter for the 7/8 blades. no need to alter your blade retention screw or blade holder. I have yet to glue that adapter to my 7/8 blades. I have not really seen the need for it
    One thing I would like to add. The 7/8 blade looks really good in my Graflex ESB. It gives the blade a closer look to the one seen in the movie (width) and provides less stress on the bunny ears. Or the clamp the blade goes through to get to the holder.
    Lastly, I was expecting to find the 7/8 blades to be "whippy" like the 3/4. But it turns out to be pretty solid, has enough flex to make a hit not so hard and returns to "true" afterwards.
    Over all I'm with Jay Gon, I too am a big fan of the transwhite blades. So I guess I'm on record for say as much too
    Quote Originally Posted by psab keel View Post
    ^^^ ALL OF THIS
    but really Psab the transwhites are worth a shot. i tried it and really liked it, even without any film inside. (but i do plan on trying film since i also notice some slight dimming about 3/4 up)
    and Noyl, thanks for the adapter info!
    MR 616 "Joe Jedi"
    I do have two pieces of Transwhite 1 inch blade stock that I have to try out. From preliminary tests they look really impressive. I have so many projects going right now that saber building has been set aside until I can get these others done, but I can't wait to get back into it!
    Follow Your Bliss
    I personally like the trans white stock over the clear blade stock (thin walled)
    The top one is the Trans white blade, bottom one is a clear blade, both p4 running 1000ma, 1 inch diameter and 2 feet of giftwrap in them.
    I also have an RLSA saber that runs a 3/4in clear blade, and personally, I just don't like thinner diameter blades, haven't tried a 7/8 blade, but aesthetically smaller blade sizes just seem to look odd to me. I think it's more hilt diameter vs blade diameter ratio, when one is off it kinda throws out what I find to be appealing to a saber build.
