Is there any way to keep the recharge port from grounding out (negative side) to the side of activation box style 14 and subsequently to the hilt frame?
May the Force Be With Us.... Always!
I have box 14 on my saber and don't have any problems with the recharge port. You could wrap the contacts on the port with electrical tape to prevent them from contacting any metal inside the hilt. The threads of the port that screw into the box should not cause any grounding. Also be sure to discard the nut that comes with the port, you won't be able to screw the port all the way into the box if the nut is left on.
My Saber, CopperHead
http://forums.thecustomsabershop.com/showthread.php?14643-DarkarNights-presents-CopperHead
Resistor Calculator: http://led.linear1.org/1led.wiz
LED Brightness Chart: http://forums.thecustomsabershop.com/showthread.php?7266-LED-Brightness-Chart
How to wire a recharge port: http://forums.thecustomsabershop.com...JST-connectors
NEVER USE 9V BATTERIES!
