Results 1 to 2 of 2
Thread: Direct Drive Modular Overdrive
    Default Direct Drive Modular Overdrive
    I've recently upgraded a couple of resistor driven sabers from lux rebel/III/P4 to LedEngin 5 watts, with a internal wiring design where you can swap resistors and LED modules to overdrive on the fly. Here is a diagram that could be helpful to the folks out there.
    Quote Originally Posted by Darth Odious View Post
    JST connectors to plug the resistors into? That's what I did on mine.
