gonna take some pressure to push it on from the one side tho, is that ok? what i did was slide it in, so its good on one end, just push it all the way to the other end? id be afraid it would break
im using a cf5.1, which is the exact same width as pc 2.0, but it just is way to tight, mean if i push it i know the board will snap
I would take some sand paper to the inside of the disk where it is tight and work it until it slides enough that you are confident it won't break.
My Saber, CopperHead
http://forums.thecustomsabershop.com/showthread.php?14643-DarkarNights-presents-CopperHead
Resistor Calculator: http://led.linear1.org/1led.wiz
LED Brightness Chart: http://forums.thecustomsabershop.com/showthread.php?7266-LED-Brightness-Chart
How to wire a recharge port: http://forums.thecustomsabershop.com...JST-connectors
NEVER USE 9V BATTERIES!
yea but its like a little nook, so that it stays secure, i dont have a file small enough, and sand paper would do a lot so it would get rid of the nook and have nothing to secure it
I don't know how advisable this suggestion will be (take at your own risk). If you take your sand paper (slightly and very carefully) to the edge of the sound board you may be able to take enough material to ease the tightness? It shouldn't take very much at all. Only other thing I can say is to find a file that will work on the disc.
If you have a Harbor Freight near you, you can buy micro files for a few bucks
Sith Happens
