Hey guys I bought the 14500 side by side that holds the pcu also and I can't seem to get my PC 1.6 to fit into the disc. Is there a special way to do it? I tried going straight in also.
Thanks
Thanks
I believe it is designed for the PC 2.0 only which is a little different in size and chip placement. It looks like the cutouts in the discs you are trying to use are very precisely cut for the 2.0 to slide in.
I have recently used the 'Acrylic Chassis Disc for PC 2.0' and put a 1.6 in it but thats because there is plenty of cutout space for the chips and sensors and the width of the 1.6 is roughly the same.
Acrylic sands very easily, just work it over in the spots where it's tight until it fits your needs.
My Saber, CopperHead
http://forums.thecustomsabershop.com/showthread.php?14643-DarkarNights-presents-CopperHead
Resistor Calculator: http://led.linear1.org/1led.wiz
LED Brightness Chart: http://forums.thecustomsabershop.com/showthread.php?7266-LED-Brightness-Chart
How to wire a recharge port: http://forums.thecustomsabershop.com...JST-connectors
NEVER USE 9V BATTERIES!
should this fit a cf 5.1 pretty easily? hopefully, i have one on the way and want it fitting very nice,
I agree with DarkarNights. Sanding the problem areas is your best bet.
Honey, you've been looking for love in Alderaan places!
having an issue, see this pic? http://www.thecustomsabershop.com/As...ysidepackC.jpg well see the grey box, the one above the led pads on the pc? How do u get the disc past it? the box is to tall? do u go from the other side and push it all the way down to the other side? seems like it would hurt the card. Not sure what to do
Yeah, looks like you have to slide both disks on from the left. I would insert the PC first, then the battery, then slide in the 4-40 rods. If you pre-assemble the chassis you might have trouble.
