Youngling
I could be wrong, but I think R- should be on the ports center - lead.
Ok, so, I wired up the charge port with the center lead going to the R-, and the saber turns on when plugged in. I don't know if this would fry anything, but thankfully it only flickered as I used the wrong charge plug that wouldn't fit. I will go back to standard AA's for now.
The saber turned on when I tried to plug it in, (switch was off) but it turns out the port I got at an electronics store is not the same size as the one sold here, so that may be the problem... lesson learned, don't try to mix vendors :P
I had this port laying around because I had lost the retaining nut on another saber port, and the nut on this one fit, so I figured the plug would, as well. Nope. So maybe the correct part would actually work. As far as wiring, it was center negative to R- and + to R+
Youngling
I think something is wired wrong, that behavior should not occur even with the wrong plug size, because with the switch turned off there should not be a closed circuit supplying any power to the LED. Please get a picture up of your wires, because this is weird and shouldn't be happening and could cause harm to your components if left unfixed.
Ok, upon acquiring the proper, M (2.1mm) sized port, not N (2.5), things appear to be working correctly with wires just twisted on. Charger light comes on, saber stays off. The wrong port may have been shorting out with the too-large plug.
New development... saber flashes on briefly when inserting plug, then turns off again, and appears to charge normally. Guess thats what I get for using parts from Resistor Hut. Plug seems a little loose, as well, similar to another thread I saw. And if I jiggle it, the saber flickers.
Youngling
This flickering behavior is happening with the switch in the off position?
yup, switch off. The saber seems to charge fine when the plug is sitting naturally, but any lean towards the edges will turn on the saber, so something is shorting to bypass the switch... i may have to make sure the switch leads aren't touching the inside of the hilt. Or maybe its just a cheap port and the shut off doesnt work properly :P
