Originally Posted by
Machinimax
If you are using a PC, it is highly recommended you use a Li-Ion battery pack as a power source. Look in the store. Tim has plenty of them pre-made and chassis disks that can hold them as well as the soundboard. That being the case, it would be in your best interest to look into getting a recharge port for your build as well. Tim sells control boxes that can hold your switches and the two ports. As for your switch question, you can basically use whatever kind you want whether it be latching or momentary. You would just have to configure the settings on the SD card to tell the PC which type of switch you are using. The aux. switch that you use for blaster blocks and lockup however must be momentary.
