I'm wiring up my first CF 5.8 with the ledengin rggb. I have GG in parallel since this board can do 2 amps, and I'm hoping to use the Red for a yellow FOC. The board is working fine, it fires up, aux switch, clashes work etc. But for some reason the FOC isn't working at all. In the tutorial here on TCSS Vader's Vault shows that he cuts the trace on the pex and uses his own resistor. It looks like something has changed on pex 2.0 - The trace doesn't run all the way through on this, so I didn't cut any of them. I just used the resistor (5ohm 3W : 7.4-2.4=5/1=5) on the posi side of the LED after the pex. My volt meter shows 7 point something coming from the board to the pex, but nothing after. Did I miss something?
Here's a couple of pics.
I didn't touch the stock configs, I did open them up to make sure FOC is enabled, and it looks like it is default.
Am I missing something?
