Results 1 to 10 of 11
Thread: Dual-Blade Coupling
    Default Dual-Blade Coupling
    I am actually looking at just using a Male and Female PVC adapter to connect and disconnect the two hilts. However...since they are pipe threads, they are tapered to seal tighter the more you tighten them. Does anyone have any suggestions on how to loose the threads, so I can connect and disconnect them easily?
    If you want the two halves to come apart quickly and easily, I have one possible solution.
    Get PVC pieces that slip together instead of thread together, then drill a hole through both pieces and insert a peg in the hole. Remove the peg when you want to separate the sabers. I've done this previously to make a quick-disassemble walking stick that fits in my suitcase while travelling.
    Jedi Padawan
    Jedi Padawan
    Boj-Vaati Mau's Avatar
    Oct 2010
    United States
    608
    Has anyone tried Rare Earth Magnets? Demon Bunnyman & I were talking about this a few weeks ago too. As you can get them in large sizes and different draw weights, you might be able to get a set that's 1.25" diameter and 20 or 30 lbs. draw. Put one each in each pommel.... Only draw back is speaker location....
    Knowledge must be balanced by Practice.
    Practice must be balanced by Experience.
    Through Knowledge, Practice, and Experience
    we gain Wisdom.
    -Boj-Vaati Mau
    Jedi Sentinel, Jar'Kai practitioner,
    and Instctor at Strafe Plains Temple
    Saber Guild: Strafe Plains Temple
    The Rebel Legion
    I thought about magnets, but also came to the conclusion about speaker placement. If they're that strong, I'm not sure how far away the speaker would need to be placed to not be effected.
    Has anyone experimented with this idea yet?
    Which idea? A saber-staff coupler or a specific way of making a saber staff coupler? If you mean a saber-staff coupler in general, I suggest you use the search feature of this forum. They have been made before and it has been discussed before, more than once.
    I went with a male female PVC adapters. I had to cut off the threaded male section, cut off a portion of the top (before the taper starts) and then put the male adapter back together, but it looks good and seems sturdy.
    Sorry about the blurriness of the pictures
    I then sanded it down and made it smoother.
    Quote Originally Posted by Boj-Vaati Mau View Post
    I talked to my dad who is an electrical engineer about this. He's not positive, but he doesn't think they'd interfere with the speakers at all or that much unless they were in physical contact. Plus after you mount the magnet in the pommel, you could potentially shield the other side to further reduce the chances. However, I did not try that approach...this time.
    Quote Originally Posted by ARKM View Post
    Sorry, I was specifically referring to the rare earth magnets coupler idea.
    Jan 2009
    I am A proud American.
    2,567
    3
    Magnets and electricity don't mix. Magnets large enough to maintain a solid connection, would mess with the battery's flow of energy... making a possible battery failure or explosion.
