Page 3 of 23 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 21 to 30 of 221
Thread: Modular pommel system??
  1. #21
    5,899
    ah... I thought you had made a recess in the bottom (still solid) you would need holes to route wires. I Couldn't tell it went through and there was a lip.
    I was thinking a recess wouldn't be bad... it would keep some more weight in the pommel.
    </center>
  2. #22
    Oct 2005
    3,521
    Thats what I had in mind madcow. I have done similar setups just not with c-clips. I probably wont make it so the speaker is held in place like that though. For you it works but for a screw on pommel you have to deal with the wire twisting issues. I will probably go with the speaker mount that is held in place by the pommel similar to the led heatsink and then the different pommel end pieces held in place by c-clip. I might even look into having that speaker mount possibly attaching to the 4aaa battery pack for a more custom look.
  3. #23
    How about a speaker holder piece that runs double-male with the speaker inside and held down by a c-spring, that you can screw on a pommel top on one end and into the hilt on the other? That would let you straighten your wires out and get your speaker locked down before applying the pommel piece.
    What is life but the passage to death?
  4. #24
    these will be great when thy're available.
    Looking forward to them.
    Step away from the Lightsaber.
    It burns.
  5. #25
    Ryma Mara
    Guest
    I know old
    But I was wandering what all was in the works.
    As soon as I get the cash to finish this one, I need to have the pommel I do have machined.
    Tim any ideas in the future for this MPS(modular pommel system)?
    I know the wire twisting issue is a problem, but say have the speaker mounted to a heat sink type disk, then whatever holds it in like the rest of the mhs then the pommel is machined for the sound to escape and no wire twisting problems.
  6. #26
    Lord Maul's Avatar
    Jun 2006
    Seattle area, Washington
    5,169
    tim has said that early in the new year the MPS will come to life
  7. #27
    Nov 2006
    Nebraska
    2,328
    Quote Originally Posted by Lord Maul
    does that mean "frankensiein" life or "whoo hoo" life?
    BLUE 3- Ready
  8. #28
    Lord Maul's Avatar
    Jun 2006
    5,169
    not sure what you mean by that but the first version of it will be out. it will only get better from there just like the mhs
  9. #29
    Oct 2005
    3,521
    The main bodys are in construction phase. Then its time to come up with all of the insert/grille designs. Feel free to post ideas.
  10. #30
    Nov 2006
    Nebraska
    2,328
    I kind of like the way a metal mesh looks like, (window screen, only thicker metal. Pipe screens
    BLUE 3- Ready
