Originally Posted by vortextwist
Exactly. In fact, that's kinda the plan I'm thinking. Of course, you wouldn't be able to use the recharge port then since the bolt holding the D-ring stud would be in its place.
One thing I noticed when installing the recharge port with this type setup...
Have the recharge port arranged where it sticks out the back of the saber a little more than it needs to. Make sure the nut is removed. Then screw on your pommel and make sure you get the port to allign with the hole. After it gets in the hole and the pommel is screwed down snug, then put the retaining nut in place over the threads. If the port isn't sticking through enough, I like to take an exacto knife or other pointy object and catch in between the threads and pull the port through enough to get the nut to be able to screw down a little. Once it's on the threads, you can tightenen it down the rest of the way without problem.
Corbin
