I like the new battery packs Tim has listed in the store, but was wondering about the specifications of the pcb's that were used on them, such the current limit and if they have built-in short circuit protection.
I was also wondering if there is a possibility of seeing an 18500 stick pack as well as some chassis discs that might look something like this:
This allows for a CF or PC to sit on top of the battery pack and works in conjunction with the speaker mount v4 to create a chassis that fits perfectly into a standard MHS shilt:
What I did there was add some double sided 3M foam mounting tape, a clear piece of plastic I cut from a battery package, and the threaded rod and aluminum tubing from the shop. I think what would work even better would be a pair of delrin discs made to allow the stick pack to pass through the bottom of the disc and then have a notch milled out of the top of the disc to snap the soundboards in place.
Anyone else think this might be a good idea, and worth Tim's time to design and have made for the store?
