Hey folks,
Well, I am going to be documenting another step by step, showing how I make sabers. This commission is the largest I have ever done by far, with many, many, features.
So, with that, let us begin.
Here is the render, as you can see, it will have a crystal chamber, dark weathering, and some other stuff. I will also be adding a full reveal chassis, so you can take the lower end off and see the inner workings. I will also be making a custom SMD LED bargraph. The same will be made to look like an ancient sith saber, so things need to look old, but still cared for. This is perhaps some of the most difficult type of weathering to do, as the interior must match the exterior... fun stuff.
So, the standard LED Module needed to be altered so the retaining washer can be placed to hold the reveal chassis.
Took the top piece and sanded it down on the belt sander
now the Retaining washer takes the place of the module lip I removed.
had to remove some material to allow the nuts to sit flush to the heatsink.
The TCSS Speaker housing didn't fit in the pommel, so I had to make on out of PVC. I will cover it in heatshrink after it is finished, so it looks nicer.
a little ring to allow the speaker some room in the pommel, better resonance.
I began to measure out dimensions for the chassis. This is what takes the longest time, as every bit of space is precious, and everything must fit in a certain way. You can see the crystal that will be used in the background.
The two angled pieces measured and cut.
rough sketch of what we have so far.
Next main thing is to finish the chassis, align the outer parts, and drilling.
Can you guess what these are for???
That's it for now, I will probably be posting an update once a week.
Any questions? Just ask.
