I had a few questions that I can't seem to find the answers to.
My first question and most important I think is about battery options.
I plan on using an Engin RGBW or RGGB and a PC or similar sound board.
I plan on running one of two ways.
With the PC I plan to run GG in series and RB in series for a FOC. Or GB and W for clash to get a cyan.
With the other board I'm looking at I am planing on running RGB in parallel for color mixing and W for flash.
Both of these options are going to take a lot of battery.
Right now I've seen a few options.
2 or 4AA, not sure if they would be able to keep up with two led let alone a third for clash.
A stick of 18650s which..MAY fit, but only just and also depends on my 2nd questions answer.
I've also found a 17670 which is 3.7V and 1500mAH, though I believe these are still just to big to fit side by side in an MHS hilt. Am I wrong on that? Please say I am.
Can anyone suggest any other battery set ups that I may have missed?
I have seen Sunrider's mod to fit 18650's side by side, however that wouldn't really work for my saber design.
My 2nd question.
How far into the hilt does the "16mm Anti Vandal Momentary Nickel Plated Switch" from the store go?
If you say 16mm I'm going to kick myself. lol
The next question is about the new 2w bass speaker.
I noticed it is a good bit thicker then the premium speaker, don't know how much exactly, looks at least 2 or 3 times thicker.
My question though, is if I'm hurting for space, is the new 2watt speaker that much better then the premium and how much thinner is the premium speaker?
My last question is about Recharge ports in pommels, like when using Insert style 6.
Does the recharge connector being there effect the sound any?
I haven't been able to find any posts complaining about it.
I just thought I would be safe and ask, it could just be a known drawback so no one complains.
I'm hoping not, as its the only place I can really see myself putting..let alone fitting a recharge port.
Thanks ahead of time for any help.
Oh and
May the blaster be at your side. *snicker*
