I don't know any of the watt/ohms stuff yet sorry. ^_^'
If i made the wrong decision as to what blade he might like best how much trouble would it be for him to swap it out later?
But as far as blades go, they are just a tube, you slide it into the blade holder and tighten the retention screw.
Then to take it out just loosen the screw and pull it out.
So it wont be any problem trying another type of blade if you don't quite like the first one you get.
which lens should i get?
Firstly you need the P4 lens holder, then most people use the 8.7 degree lens.
Lens holder http://www.thecustomsabershop.com/Se...older--P7.aspx
Lens http://www.thecustomsabershop.com/Lu...ngle-P537.aspx
do i need a resistor for the other LED?
You need to resistor all accent leds. That means blinky lights, button lights and so on.
However the PC is an led driver so you do not need to resistor the blade led.
In response to FenderBender.
AA = 14500 in my head, sorry. lol
The 18650s are popular for one reason 2600mAH vs 900mAH.
Even 4 14500 are only 1800mAH vs 2600mAH for 2 18650s.
Running 1 led that isn't so much a problem, but for people running two and third on flash.
Still, yes they really are a pain to find room for....unless your sunrider, then everything seems to just fit right in for you.
