Results 1 to 5 of 5
Thread: 3mm LED's
    Default 3mm LED's
    Hi ! I found some really nice green LED's . They are 3mm , 8000mcd , 5-15ma . The only problem is that they are 20 degrees . I am planning on making 4 strips , about 70 led's each . Do you think the blade will be even , without dim spots ? Also do you think they will fit in a standard tcss 1 inch blade ? Thanks .
    The angle is too shallow. Most of the light they emit will be directed at the tip of the blade rather than the sides. You could use a single strip of 45 degree leds and it would probably be brighter.
    Jedi Padawan
    Jedi Padawan
    Boj-Vaati Mau's Avatar
    Oct 2010
    United States
    608
    Check out Makototsai, a master of the art of string blades. Please peruse his threads...
    http://forums.thecustomsabershop.com...earchid=464252
    There was also a facinating article on FX-Sabers about cutting down & dishing out LEDS for maximum light dispersion...
    Knowledge must be balanced by Practice.
    Practice must be balanced by Experience.
    Through Knowledge, Practice, and Experience
    we gain Wisdom.
    -Boj-Vaati Mau
    Jedi Sentinel, Jar'Kai practitioner,
    and Instctor at Strafe Plains Temple
    Saber Guild: Strafe Plains Temple
    The Rebel Legion
    I cant find the thread on fx-sabers ( . That would really help . Thx anyway .
    That would be the Supernova thread, http://www.fx-sabers.com/forum/index.php?topic=27559.0
