Originally Posted by
Don Se Wion
Yep, the board seems to be fine.
One additional test I can suggest is this, but it requires some fancy soldering.
I would take a small wire and solder one end temporarily to the left side of resistor R1 (keeping the board with the LED+/LED- side on your right and the swing sensor on your left). It doesn't need to be a perfect soldering, you just need to keep the wire in place for your test.
The other end should be attached to the base of the TIP42 (or another PNP power transistor); as usual wire the emitter to the battery positive and the collector to the LED positive.
Turn the board on and read the current.
The aim of this test is to verify if your TIP42 is going into saturation state or not.
If you get high current value this way, you can consider following my customization and remove both R1/Q1 using the TIP42 in their place.
