Yes, the shock "sensor" is a spring inside a tube. When it's hit/vibrates hard enough it sends the signal to the board that it's sensed a clash. In an MR it literally just hangs inside there. It doesn't need to be mounted to anything.
The MHS builder is not a "we make you this" option. It is dirt easy though. If you can screw two things together you're good to go and can put the hilt together. Tim already has a speaker mount option. If you want it all done for you then you'll have to talk about "custom" work with him. That totally defeats the purpose of this site, but if you got the money... whatever.
</center>
