Luxeon Driver Help
Hello First Post, I just recieved my order and I am building a Led Saber, I ordered the Luxeon Driver and have a question regarding the shock sensor for the clash and lock feature. Will you be carying one soon or is it best to disasemble a Hasbro Saber for the Part?
Since the hasbro board is compatible with Corbin's driver, you may as well just get one and hook it up. You can wire the clash sensor up to both the driver and the sound board.
What Ultra said. []
I'm looking into carrying separate clash sensors, but if you're going to buy a Hasbro sound module for the sensor, you might as well use the sound board itself as well. I just picked up 10 of them from Ultra. They work quite well with my driver.
Corbin Das
Corbin_Das@Hotmail.com
Corbin, could you show how to wire up the system with the c&l and the sound module/sensor wired up? I checked your site and didn't see it. Thanks[]
look where he talks about wiring diagrams and click on the unformatted version. its there.
I just took a better look. "Now I owe you one." Thanks for showing me where to look, I guess I just missed it.
Mur-Pa DiLos, we're all friends here and im glad to have helped out.
See, the REAL trick is hooking up the LED driver to the PLI and a sound module with the safety switch. That's what I hope to figure out soon.
Also trying to figure out where to put a SPST "breaker" tact switch to open the circuit to the power-on when the blade is removed. I'm thinking between the safety/PLI switch and the power-on switch.
What is life but the passage to death?
