Blade Flicker without Sound???
Hi all.
I have been doing some events in very noise-heavy, dim lighting environments as of late and was trying to determine if there is any way to create a saber blade Flicker (idle flicker pulse, saw tooth, etc) without the need and power eating of a standard Sound Board with flicker function onboard. Being that the sound effects are utterly lost while at these locations it seems such a waste to have to power the sound just for the visual effect.
Any suggestions are most welcome. I am sure there are plenty of tech-heads out there that can build simple circuits for this effect, it is just very much beyond my level of electronic experience.
Sith Acolyte
I take it the Static Shimmer would work for my needs on a Constant Current Driver?
Experimentation.. the heart of any good saber build.
The Shimmer / Flicker Effect given life... with Ramp Up/Down and all the usual goodness of the TCSS Constant Current LED Driver.
Sadly, the camera sees the flicker far better than the eye does. I will have to try the various colors and see if a blue or red grabs the eye's notice a bit better.
