The picture isn't really showing a chassis, just a board and batteries with the PCB. If you want to build a chassis, the shop has lots of options:
http://www.thecustomsabershop.com/Ch...Parts-C74.aspx
The easiest way to secure everything once it is put together is to use PVC shrinkwrap. If you build your chassis correctly, you'll be able to slide it right in to your hilt and screw the pommel on.
EDIT: I just looked at your drawing again and caught on to the fact that you're looking to use a PVC chassis. That will work too. I would still recommend PVC shrinkwrap for the PC and battery.
