Page 2 of 2 FirstFirst 1 2
Results 11 to 11 of 11
Thread: Help on my wiring schematics
    Ha now i feel a little silly, but yes, those pins match up with the colors.
    i will try to add a written explanation of what my wiring is.
    3.7v lion + connect to 3.7v Lion + (red)
    3.7v Lion - connect to 3.7v Lion - (Black)
    Creating Battery Pack
    one +/+ (red) combo goes to PCB B+
    one -/- (black) Combo goes to PCB B-
    P+ Connects to Recharge Port 2.1mm Female + (Right Pin)
    http://www.plecterlabs.com/Media/Doc/RechargePort.jpg
    P- Connects to Recharge Port 2.1mm Female - (middle Pin)
    BM connects to ??????
    (so this is where i get a lil confused, Does: )
    Recharge 2.1mm female + connect to Obsidian Sound Board Batt/LED + (Red wire on my drawn diagram) Port 6 on NovaStars
    http://www.saberforum.com/Obsidian%2...(Novastar).jpg
    Recharge 2.1mm female - Connect to Obsidian Sound Board Batt/Switch (Black wire on my drawn diagram) Port 5 on NavaStars
    Recharge 2.1 mm female + connect to Obsidian Sound Board Switch Lead (light Blue wire on my drawn diagram) Port 1 on NovaStars
    (is this Correct?)
    (I Also am little confused about the CCD)
    Obsidian Sound Board (OSB) + Switch (light blue) (Pin 1) connects to CCD SWA
    CCD SWA Connects to Switch Resister 22 OHM 1/4w
    Switch Resister 22 OHM 1/4w connects to DPDT Latching blue ring Illuminated switch LED Terminal +
    OSB - Batt/Switch (Black) (Pin 5) Connects to CCD SWB
    CCD SWB connects to DPDT Latching blue ring Illuminated switch LED Terminal -
    OSB + Batt/LED (red) (Pin 6) connect to Power Level Indicator + (red on the PLI??)
    OSB - Batt/Switch (black (yes it is blue on my diagram) connects to PLI - (Black on the PLI?)
    OSB - LED (pink) (Port 3) connects to CCD LED -
    CCD LED - (pink) connects to all LED's -
    OSB + (red) (port 6) Connects to CCD LED +
    CCD LED (red) + Connects to Res 5.6 ohm 10w
    res 5.6 ohm 10w (red) Connects to Lexeon Rebel Royal Blue 3.4v 700mA +
    CCD LED (red) + connects to 4 Res 150 ohm 1/4W
    4 Res 150 ohm 1/4w (red) connects to 4 Mini LED's
    OSB Speaker + (orange) (port 2) connects to Premium speaker +
    OSB Speaker - (neon green) (port 4) connects to premium speaker -
    CCD stat (blue pen) connects to Clash Censor
    CCD Stat - ( Light green) connects to clash censor
    Do you judge me by my size? With the force I am strong.
