this is actually a two part question:
i was thinking, for the saber i'm building i want it to be able to ignite ergonomically easy in both a standard hold as well as a reverse grip.
i was planning on mounting some kind of a switch in my control box towards the emitter end, but i was also wanting to add a switch that will do the exact same thing functionally to the lower end of the hilt.
part 1 of question:
would i simply solder the pos/neg wires of both switches to the exact same paths?
maybe just splice them together?
so basically:
if i click switch one, it turns on, click switch one again it's off
if i click switch one, it turns on, click switch two it's off
if i click switch two, it turns on, click switch two again it's off
if i click switch two, it turns on, click switch one it's off
part 2 of question:
i'm mounting the sink tube over the PVC with two button head screws in two different parts of the hilt.
as it stands now this is more than stable. it's very solid.
that being said, if i replaced one of the button head screws with this switch: http://www.thecustomsabershop.com/Pu...tton--P40.aspx
would that be sturdy enough?
my concern is that these switches are plastic, not metal and won't be sturdy enough?
