Hello all, If you would be so kind to give this a quick look it would be much appreciated. Ill be building this saber with alot of Firsts. First with sound, lighted AV switch, and hopefully a led in the pommel. So I looked up the resistors I would need, read the forums for the last three months, and looked up tons of diagrams and threads till my head hurt. But still I will probably mess this up lol( Im still electronically slow but trying hard to learn). So if you could give me some advice or point me the right direction that would be great. Thanks for sharing your knowledge.
Here is my parts list:
Luxeon Collimator Lens 8.7 deg viewing angle
Seoul P4 Lens Holder
Seoul P4 Blue
SPST Momentary blue dot Illuminated switch
MHS speaker and battery holder 4 AAA
1/8" Adhesive lined heatshrink tubing 2 feet worth
Swing sensor
Clash sensor
26 gauge wire( 4 colors 2 feet of each)
150ohm 1/4w resistor( for the SPST AV switch Blue dot)
220ohm 1/4w resistor ( for the accent LED)
3.3ohm 5w resistor ( for the P4 Blue)
Hilt style 2 with standard style switch hole
MHS choke style 3
Screw on LED blade holder style 4
MPS Pommel style 4
Media blasting ( on choke and pommel)
Machine recessed AV switch hole( on main body)
Drill & Tap Hole (for blade holder and covertec)
8-32 x 3/8" socket head( for covertec)
8-32 x 1/4" Set screw (for blade)
MPS Clip (for pommel insert)
MPS Insert style 1
Machined button for Covertec clip
Blade Holder Powder Coating(copper metalic)
Main Body Powder Coating(copper metalic)
1" Hilt safety plug (For Safety)
I have a Blade and the 2010 Obi-wan Econo Sound board and will buy a pnp power resistor at radio shack
I will try to use this diagram without the recharge port(hope it is right one for me). But am going to have to figure out how to run another accent led for the lighted pommel since the one in this diagram runs the AV switch led..Any Advice??
Here is what saber will sort of look like
Thanks again
