The adapter from Random Sabers uses a flush mounted set screw to pin the blade in. As such you can either use the same setup to pin the reducer to the adapter and then use your blade retention screw to hold in the reducer or drill a hole through the reducer and line it up with the hole for the blade retention screw so that you can pin the adapter directly using the blade retention screw. You really dont need just one screw pinning EVERYTHING in... but that can be done as well.
The main thing that I would be concerned with is that the reducer is plastic, not metal. Could be an issue when sparring. You won't know until you try.
