Hi,
just finished my first custom:
Parts:
- Empty hilt from JK-Sabers
- Huey Jann 5W blue LED
- PC-L Lightmeat
- Samsung 18650 protected 2600mAh
- very small and short momentary vandal resistant switch
- small momentary AV switch for the FX
- TCSS speaker with chassis
- TCSS trans white thinwalled 1" blade 36" length with a little diffusor wrap
- standard recharge port
Recharge port under small circuit board:
A small demonstration video without comments:
The hilt is made of one large tube, so it is very tricky to put everything inside.
That´s why there is no chassis for the electronics at the moment.
I haven´t decided if I put another (brighter) LED.
The Huey Jann is as bright as my P4, but has a darker hue and needs 1400 mA.
I like this dark hue and want to keep it if possible.
I was thinking of a Ledengin 5W blue or a 10W BBBB, but then I need more than one cell.
Would you recommend using 4 unprotected 14500?
2 in parallel and these 2 packs in series?
How to realize the recharging and PCB then?
2x 18650 wouldn´t fit.
And another question about the PC-L.
Do I need a resistor for a red LED at 2.7V?
