Results 1 to 3 of 3
Thread: Changing MR Tranistors for more current??
    Default Changing MR Tranistors for more current??
    So these are the transistors on my MR Luke ANH board. i somewhat understanding more and more about all this electronic stuff. but the specson this sheet vex me.
    http://www.datasheetcatalog.org/data...s/mXyzqxst.pdf
    azmaria del said the MR board puts out about 1000ma @ 3.5v, but wasnt sure if per Lead or combined. Scottsaber talked about , in same thread, replacing the transistors on the board to get more current. I want to try this. i got the MR board for cheap so i dont care if i blow it up but would prefer to try to do it close to right the first time as i can.
    The strawhat led's i bought are 160degree angle , 12k-14kmcd @ 3.2v at 25ma. So i have 90 of these on my MR board @ 1000ma , they are theoretically getting 11ma each. less than HALF what they are rated. They are BRIGHT as it is , getting more current will get more light?
    Feel free to correct anything i am wrong on. How else will i learn
    Jedi Knight
    Jedi Knight
    Azmaria Dei's Avatar
    Dec 2010
    1,022
    the 1000mA out is total between all of them. and i don't recommend swapping them out for higher power ones. the board is made to put out 3.5V @ 1000-1200mA. any more and you're asking for something to melt.
    Sep 2008
    Home of NUCLEAR JEDI SABERS
    1,027
    Quote Originally Posted by Azmaria Dei View Post
    -C
    LOCKHEED
