Results 1 to 9 of 9
Thread: help with DPDT switch
    Default help with DPDT switch
    I have searched and searched the forums over the last few days and can't find a wiring diagram for a latching DPDT switch .
    I am trying to wire it up with out a soundboard
    It is a direct drive
    here is the diagram that i am using of how i have it wired
    the problem is i am not sure that i wired it right the led is very dimm only about 2" of blade lit up .
    p4 led
    3.3 5w resistor
    2AA battery pack
    Hrm, what kind of batteries? If those are regular alkalines, you're only giving it 3V. The resistor you've chosen would work for a 4AA alkaline pack.
    Jedi-Loreen's Avatar
    Dec 2005
    Not of this Earth
    6,077
    Ok, what type of batteries are you using in the battery holder? If you're using alkalines, then you don't have enough voltage going to the main LED.
    And what color P4 are you using?
    Edit:
    I should have refreshed the page before I hit submit.
    blue p4 led
    ok so the resistor for the led is whats wrong then i need this one is this correct
    http://www.thecustomsabershop.com/22...stor--P11.aspx
    Sith Adept dgdve's Avatar
    Aug 2009
    Virginia (near DC)
    647
    I just replied in your other thread but Ill say it here as well...
    the p4blue takes 1ohm 2W @ 3.6/3.7v.. use the resistor caculator in the store(front page) located on the left side of the screen towards the bottom, I really hope this helps
    Quote Originally Posted by Gin Malinko View Post
    just an added note on this.
    I vote dgdve as the site's motivational speaker. haha
    "Yes Lord Vader, and I too have a gift... for you.."
    "There is no good or evil, no black or white.. There is only.. Perspective"
    Dec 2005
    Not of this Earth
    6,077
    If you're using alkalines, for 3V, then you don't have enough voltage to properly light the LED. PERIOD
    Using a smaller value resistor won't help.
    ok so i just need to go for the AAA battery option then ..is that correct
    thanx
    Dec 2005
    Not of this Earth
    6,077
    If you're using alkalines, yes.
    Don't forget to recalculate for the proper resistor value for both LEDs.
    thanx ....got it now ....thanks for all the help
