Hello everyone, im finally going to start my first build after lurking the boards for forever. I tried to learn as much as i could from reading around and just want to make sure i have my bases covered.
Main body pieces:
Screw on LED blade holder style 19
MHS choke style 1 short
5" Fluted double female threaded connector
MPS Pommel style 7
(I'm Planning on drilling my own switch hole and tapping it)
Blade:
1" Thin walled Trans White PolyC 40" long (36 inches +$0.50)
Blade film (Single wrap, 1" Thin walled)
LED/Electronics:
Luxeon Collimator Lens 8.7 deg viewing angle
Luxeon Rebel Lens Holder
Luxeon Rebel Star (Green)
Heat Sink shim for Rebel stars
BuckPuck 700mA 4-wire (is it possible to swap this for the 1000mA version for brighter blade?)
DPDT Momentary green illuminated switch
Bezel for illuminated switches
150ohm 1/4w resistor (for switch led)
4AAA battery holder
Speaker mount.
Premium Speaker
Econo soundboard
Edited list.
Some things i'm concerned about and not sure of are firstly will everything fit? Will that battery setup be able to supply enough/too much voltage? And what Hasbro Econo boards are the best eg. obi, vader, windu?
And here is a pic of what i want it to look like
Attachment 4912
