Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
Thread: Accent LED Brightness
    Force Aware Darth Enab's Avatar
    Jul 2010
    America the Beautiful
    65
    Question Accent LED Brightness
    I've been testing my parts with a breadboard, and wanted to see how my accent LEDs would light up my milky quartz, which I've heard diffuses light good. When I put my crystal up to my LED, it hardly lighted up. I tried wiring them in series and parallel, and with multiple resistors -- nothing. The LEDs themselves light up fine, but cannot light up my quartz. The dimentions of my milky quartz are about 1.6 inches long and 0.75 inches wide. I tried to light up smaller crystals too, but nothing. It doesn't light up in a light or dark room. A Christmas light lit it up fine, but bulbs, I believe use AC current. Help?
    Two there should be. No more. No less. One to embody the power, the other to crave it. -Darth Bane
    If a Luxeon III gets hot enough to melt...[hot]glue, something's wrong with your wiring! -Jay Gon Jinn
    I use lasers to light opaque crystals. For a 1.6 in long crystal you would need 1 laser on each end. I would use a smaller or clearer crystal.
    Jul 2010
    65
    Quote Originally Posted by Sunrider View Post
    The thing is, I don't have access to lasers or many other crystals, although I have more access to crystals than I do lasers. I've tried with smaller crystals, as in a half inch tall and quarter inch thick. Even those didn't light up.
    Sep 2008
    Home of NUCLEAR JEDI SABERS
    1,027
    can you post up pics of your crystal? also what size led are you using?
    if you use two AAA batteries for 3V, any 5mm led should light up bright enough to light up a crystal...
    LOCKHEED
    Jul 2010
    65
    Quote Originally Posted by cannibal869 View Post
    I'm using two of the "Red LED Indicators" (the kind with the bezel) sold by the shop powered by 3 NiMH batteries (3.6V) with an 82 ohm 1/4 watt resistor.
    I'll have pics up soon.
    Jedi-Loreen's Avatar
    Dec 2005
    Not of this Earth
    6,077
    No wonder you're having trouble lighting up your crystal, those LEDs aren't very bright. There are high output LEDs with clear covers that are much better for this. But you'll have to source those yourself.
    Rhyen Skytracker's Avatar
    Feb 2009
    Covington, GA
    2,550
    I use high output 5mm LEDs to light my crystals and they are bright. http://www.youtube.com/watch?v=FMRluDtTCHI
    Jul 2010
    65
    Oh, well I guess problem resolved. I'll go out and get a couple other LEDs and save the accent LEDs for another project. *HintHint*
    Quote Originally Posted by Rhyen Skytracker View Post
    I think I'll try that.
    Jedi Initiate Loachri MacTalabh's Avatar
    Dec 2010
    Terra System; Aurora, Colorado
    402
    What kind of laser are you talking about, the pointer type?
    Jedi Knight
    Jedi Knight
    Azmaria Dei's Avatar
    Dec 2010
    1,022
    the accent LEDs here are not that bright - likely so you don't blind yourself with your own saber while dueling. but there's a place called google that can help you find all sorts of them that are really bright. ^_^ and your local electronics store should have some too.
