This saber is being built for a friend of ine in the rebel Legion that is putting together a Mara Jade emperor's hand costume and is based on the Mara Jade hilt as seen on the "Decipher" card game card, and the version sold at Parks Sabers. It won't be an exact replica, but should be similar in appearance.
Here's the basic parts this will be made from:
MHS blade holder style 15, a 9" double female threaded connector with custom machined grooves, a pommel style 9 w/mpsi style 12.
The emitter/blade holder....I have the correct t-grip material to add to this later...that will likely be the last thing I do on it.
The custom machined grooves on the 9" MHS double female threaded connector....Tim did a great job on that as usual!
The rear grip sleeve.....I'll have to drill and tap this for 24 button head screws....that'll be fun, I'm sure
The batteries....Li-Ion Trustfires.....premium speaker....two-AA battery holder and style 3 speaker mount.
The soundboard...a Petit Crouton. I think I'll be using the Shatterpoint font by Madcow on this one.
Also seen there are the two switches...the purple dot AV is going to be the main activation switch, and the smaller one will activate the blaster deflection and the blade lock-up effects. Mara's saber actually has a control box of sorts near the emitter, but that wasn't going to work on this since the store doesn't have one that will fit, and ordering one form Parks takes forever. Even then, I'd have to have it shortened somehow, since the ones he sells are 2 1/4" long, and this saber only needs one about half that length. I think it'll look better with the light-up Anti-vandal style switch anyway.
These are the new chassis discs style 2 with holes and will be used to hold the soundboard in place. this is the first time I've used the new chassis discs, so this should be fun!
This is the main blade led....it's a 3W RGB, and has all three main colors, red, green and blue under the center dome. I'll be using the red and blue to make a violet blade for this one similar to what I did for Chrome Saber 31.
