Results 1 to 9 of 9
Thread: blade sizes
    Lord Maul's Avatar
    Jun 2006
    Seattle area, Washington
    5,169
    Default blade sizes
    does anyone know if tims blade will work with one of Ultra's luke conversions? i think i might of read that it doesn't fit but i could be wrong.
    Sith Lord Do-Clo's Avatar
    3,830
    Ultra's Luke ROTJ uses a stock MR blade and holder which is smaller than the 1 inch poly-c blade that Tim sells. In order to make it fit you would have to sand the blade where it fits into the blade to make it fit in the Luke ROTJ mr saber.
    <center></center>
    Lord Maul's Avatar
    Jun 2006
    5,169
    how much would that effect the strenght of the blade?
    3,830
    The effect on the blade is not a facter since you are only sanding a small amount off, my guess would be about 1-2 mm would do the trick.
    <center></center>
    Lord Maul's Avatar
    Jun 2006
    5,169
    what grit sand paper would you reccomend?
    3,830
    You could start with 180 grit and finish with 400 grit to make it smooth to slide in the holder smoothly
    <center></center>
    Lord Maul's Avatar
    Jun 2006
    5,169
    and to sand it evenly i would hold the sandpaper in one hand and turn the blade in the other?
    3,830
    Correct, this will take a while but it will work.
    <center></center>
    What a lovely Q & A exchange thread.[8D]
    Less talk, more action........
