Results 1 to 10 of 13
Thread: Possible recharge-port location
    Jedi Initiate Loachri MacTalabh's Avatar
    Dec 2010
    Terra System; Aurora, Colorado
    402
    Post Possible recharge-port location
    I am wondering. Is the Machined button for Covertec clip, have the dimensions to recess the recharge-port in the middle, also acting an a anchor for the clip? Is this a good idea?
    Jan 2009
    I am A proud American.
    2,567
    3
    Many people have done this before and the effect is quite nice IMO, searching covertec recharge should get you some results.
    One thing you need to keep in mind is you will nt be able to insert a kill key when the saber is on your belt.
    Dec 2010
    402
    Until I can come up with a Custom, I won't be putting it on my belt. If you would like to know what I have in mind for one look in the Costuming Thread.
    Jan 2009
    2,567
    3
    You mean costume right?
    Then with a little searching and reading, figuring out how to make it shouldnt be a problem!
    If you do make one, be sure to post pics.
    Dec 2010
    402
    Sorry, fingers were ahead of my brain. Pictures, you bet I will. Keep a Weathered Eye towards the middle of January. OK, So that sounded like a Pirate.
    As Cardcollector said, this has been discussed before.
    Some abandoned the idea because they didn't think the port could take the weight, that it would snap. (?)
    This might be possible if your saber is very heavy..
    Dec 2010
    402
    Physics, says a tube(the port) is stronger than a bar (a screw). Therefor it should hold. The main body of my saber is a sink tube, so it is that much lighter.
    Jedi Initiate
    Jedi Initiate
    equinox13's Avatar
    Oct 2010
    Zama City, Japan
    493
    1
    i'm not so sure that applies to threaded tubes at roughly the same size as the bar, which is also threaded... but the sink tube making it lighter is a plus.
    Now known as Azmaria Dei
    Dec 2010
    402
    Yes, threads create a weak point. What if I did this? Run the port through a piece of tube ever so slightly bigger, leaving the threads exposed so I can tighten the nut.
    Jedi Initiate
    Jedi Initiate
    equinox13's Avatar
    Oct 2010
    Zama City, Japan
    493
    1
    not sure... i'm not a mechanical engineer. sounds like it would be stronger though.
