Results 1 to 10 of 56
Thread: Help for my First Saber Eletronic parts
    Talking Help for my First Saber Eletronic parts
    Hello, im new here
    i live im brazil, and i want to make my first saber
    i already have one from ultrasabers
    i want to buy only the essential parts to make the saber or else is cheaper to buy one already constructed
    im going to construct the hilt with the things i found here, like pvc sink tube
    so i make a list the things i want to buy
    let me know if i really need all or something is missing
    thanks
    4AA Battery holder
    Seoul P4 (Green)
    Collimator Lens 5° viewing angle
    3.3ohm 5w resistor
    Push on/push off switch with black button
    Luxeon III/P4 Lens Holder
    Star thermal tape pad
    Heat Sink shim for Rebel stars
    that is for the eletronic parts
    and for the blade, i think its all this
    Blade film (Single wrap, 1" Thick walled)
    40" LED blade diffuser for 1" thick walled blades
    1" Thick walled Polycarbonate 40" long
    i want the blade for battle
    im right?
    thanks
    Sith Adept dgdve's Avatar
    Aug 2009
    Virginia (near DC)
    647
    you will not need the "Heat Sink Shim for rebel stars". you only need that if you use a rebel star Led but you are using a p4 so you dont need it.
    you WILL NEED a Heat Sink and some sort of blade holder. I'll look over your list when I have more time but I think thats it, I hope that helps
    Jan 2009
    I am A proud American.
    2,567
    3
    No heatsink shim
    You will need a BH holder though
    Make sure your switch is latching.
    Jedi-Loreen's Avatar
    Dec 2005
    Not of this Earth
    6,077
    The Push-on-Push-off momentary switch acts like a latching switch. I keep trying to tell people that.
    Aug 2009
    Virginia (near DC)
    647
    Thats the old school switch and YES she's correct (as always). I'm sure CardCollector read it as if he were using an AV type switch (not many actually use the slide or older push on/off switch with the rubber boot anymore.. So your both correct, Yes he needs a latching type switch, and Yes the switch he has chosen does act as a latching(its been confirmed many times).
    But yeah No shim, add Blade holder (which will come with a heat sink for your LED)
    I hope this helps
    Jan 2009
    2,567
    3
    Quote Originally Posted by dgdve View Post
    I'm sure CardCollector read it as if he were using an AV type switch (not many actually use the slide or older push on/off switch with the rubber boot anymore.. So your both correct, Yes he needs a latching type switch, and Yes the switch he has chosen does act as a latching(its been confirmed many times). helps
    Yeah, I wasnt thinking about the basic switch...
    Sorry for not clarifying...
    i was looking for this kit here, that sells in the store
    http://www.thecustomsabershop.com/Bu...cs-Kit-P6.aspx
    but the led is out of stock
    so i was looking the leds from the luxeon site
    but there are diferents leds, which one is the right?
    what mean the "lm" numbers?
    thanks
    lm means 'lumens', or the brightness of the LED (as relative to the other LEDs of the same brand). Lumen ratings are sometimes relative to the brand for which they are named and are independantly rated by each manufacturer. So, don't get wrapped around it too much. Typically, you are more concerned with how many 'watts' the LED is so you can focus more on how you are going to power the LED. The average LED that we use is a 3W LED, which lives very happily between 2.5 and 3.9V (typical, depending on the color) and uses somewhere between 700 and 1400mA.
    To give you an idea about how much power that is, a regular alkaline battery is 1.5V and 1000mAh (milliamps per hour). A Li-Ion 18650 cell (about 1/3 longer and 1/4 fatter than a AA battery) puts out 3.7V (4.2V max charge) and 2500mAh.
    Tim only sells the brightest of each LED type, but the bin (shade of color within a particular color) is random because manufacturers don't like to sell specific bins in less than groups of 1000.
    He may be out of stock right now, because the Halloween and Christmas rush probably took a big toll on his inventory, but he should be restocked shortly after the first of the year. He's trying to catch up on orders until after Christmas for right now.
    He is an extremely fast, shipper. So if you plan on ordering through someone else, keep in mind that by the time he gets them back in stock and ships them, you may have them before you get them from someone else.
    Jan 2009
    2,567
    3
    @ Revenge of the Seth- That LED is out of stock because it is no longer being produced. So unless TCSS is releasing in batches, it probably won't be available for purchase again.
    The difference between all those LED's are simply the effecincy of the LED. Meaning that it will give off greater Lumens because it is mroe efficient.
    The LM means the lumen output- or how bright the LED when driven at full power.
    If you could remove the link that would be great, because TCSS sells the same products and we wouldn't want to take away business from TCSS now would we? I can understand your pusting though, since you LED is out of stock.
    I personally wouldn't use the LUX III, I have before and it isn't my favorite. I would use a LEDengine, because it is a better orange IMO. Some googling will find it for you...
    This thread should help you in future reference in LEDs you can use...
    http://forums.thecustomsabershop.com...ightness-Chart
    so which led is better?
    the one that sells on the TCSS is good?
    or recomend another?
